ultrajim49
Those who read my review of the BO6040 ( http://www.autopia.org/forums/showthread.php?s=&threadid=16906 ) know that I have a hood to test things on.
The center part was my test area for wet-sanding.I have never done this before, but learned a lot since then:up .
The sanding paper = Picture 1:
http://www.autopia.org/gallery/showphoto.php?photo=1056&papass=&sort=1
Picture 2: after sanding:
http://www.autopia.org/gallery/showphoto.php?photo=1057&papass=&sort=1
I let the sanding paper soak in plain water for a half hour.
With a sponge I wet the area to be sanded, as I was sanding, the surface dries, therefor I held a spritz-bottle with a soapy mix(just like claying) to wet the area again.
I folded the sandingpaper around a kitchen sponge to get a better grip and for better distributing the "force".
I think a rubber sanding block would have been better still, for a more even finish.
Picture 3:compounding:
http://www.autopia.org/gallery/showphoto.php?photo=1058&papass=&sort=1
After drying the surface you need to compound to get the sanding marks out: 3M fine cut with wool pad (Makita-wool pad)
As you can see there is a haze left by the compound.
Perfectly normal.
Picture 4: polishing:
http://www.autopia.org/gallery/showphoto.php?photo=1059&papass=&sort=1
To get the compounding haze out you need to polish: 3M machine polish, and Megiuars polishing pad
the apearance improves greatly.
Picture 5:glazing
http://www.autopia.org/gallery/showphoto.php?photo=1060&papass=&sort=1
Glazed this hood starts to look like something "Autopian", allthough you can clearly see scratches wich go straight through the clear:sosad
Picture 6: the result after waxing:
http://www.autopia.org/gallery/showphoto.php?photo=1061&papass=&sort=1
After Meguiars Gold Class paste wax: shows that imperfections (scratches) are not hidden with waxing
That's about the best I could get that hood
What have I learned?
I have learned that wetsanding isn't something to be afraid off, providing you use the wright steps in the wright order, this is VERRY agressive , and will surely take alot of clear away, but sometimes something as abrasive as this might be nececeary(sp?)
Christiaan
Perfectly normal.
Picture 5:glazing
Christiaan
