+I have read that wax stripper can leave marks? Which product would you suggest for a rookie. I will be doing this by hand. My car has not had a lot of waxing. Thanks
Depends on what you are using dawn will not remove Duragloss unless you want to wash it repeatedly.Ive always heard that washing with dawn will remove wax
Dawn will dry out the paint. I would not recommend using dawn. It's also more acidic for removing food grime.
Well, it must be true then, eh?I'll say it............
Totally ridiculous. Even Zaino says to use it the first time to strip the surface.
Used on a regular basis it would be foolish but once a year or so to thoroughly clean & strip the surface causes zero problems. I've done it for years (as have many here) on customer's cars. and my own. When they are in need of a total makeover, it has worked flawlessly. You have no basis for your statement except for what you heard somewhere.
I doubt that it will take much of an effort to remove any remaining wax..... My car has not had a lot of waxing. Thanks
really :inspector: clearcoats can't be dried out , but the dawn can dry out the rubber moldings, especially around the windshield and windows :notme:
Guys - as long as you don't get the Dawn and the Simple Green mixed together during the wash, you're okay. However, if you really want to "dry out the paint" and open a portal to Satan's fifth dimension, just let their rinse streams cross. Trust me, I'm a ghostbuster - I know.
Sorry RF, I couldn't resist.Not trying to start a Zaino war, but just because Sal says it doesn't really make it gospel or anything now does it?
I'm probably also in the minority but I haven't used any dishwashing liquid soap to wash a vehicle in so long now I couldn't even tell you when or the brand (it has been decades).
As Black Bart noted a wash followed by a claybar and/or a polishing step(s) works fine for me if I feel the need to a "clean slate". But in the OP's case, where ...
