Buffautodetail
Anybody use them on paint?
David Fermani said:Is it the waterblade that is causing the problems or the lack of understanding how to take the proper precautions to eliminate damage? If you're going through the proper rituals when you rinse via powerwasher, monitor the cleanliness of the blade and using it on sections of the vehicle that would not have exposure to isolated abrasives, then you're in the clear.
Buffautodetail said:I don't think their garbage I use them multiple times a day.
David Fermani said:What's to say that same spec of sand that can get lodged in your blade will not get lodged in your towel and cause damage too. It's alot easier to detect this with a blade because you can constantly inspect/clean it. You can't do this with a towel. Yes, the severity could be different, but like I said, if you use professional experience & common sense I feel these tools can be a great drying aide in certain scenarios.
