Boss_429 said:III,
The main reasons you do tires/rims/wheel wells first, is because you don't want water sitting on the paint surface turning into water spots while you are washing the tires/rims etc. If you try and dry the vehicle first before duing the tires/rims, you'll just get more water back paint as your are washing/rinsing those areas.
Don't forget to use a different wash mitt on the rims and grungy areas. You don't want to use the same mitt on the paint.
