Very Basic question
Saleenfan
I get the process for using a PC but im a little confused on what the heck the "finishing pad" is for? The cutting pad is for using a heavy/medium cut polish the polish pad is for a light cut polish and the finishing pad is for..... what? is this where you use the sealant or what?
Also is it a good idea to use 2 different types of product on the same pad or should you have a different pad for each product?
^&04types said:
Finishing pad is for applying your final glaze or wax. Helps spread the product evenly. You can also remove it with this pad too.
Finally a straight answer. thanks!
Anything about using multiple products on one pad?
I would not use multiple products on one pad.
I use the finishing pads to apply final polishes if a polishing pad is still leaving marring. To finish my GP down I always have to use the finishing pad to get it perfect.
use one product per pad, it's not a good idea to cross contaminate...
