2drtahoez71
Will this work, or should I add some Vanilla Moose Carnuba to my lineup (id rather not, seeing as I already have a very nice carnuba product...s100)
andriver said:Wait until you have used up all your wax. Then order Carnuba Moose.
I've tried both combos in a side by side comparison. VM/CMW is slightly wetter than VM/S100. However, VM/S100 is more reflective and brings out a bit more metallic flake. You won't be sorry with either combo.Scott P said:Vanilla Moose and S100 doe slook very nice togehter. Vanilla Moose topped by Carnauba Moose Wax looks a bit wetter IMHO.
awd330 said:I've tried both combos in a side by side comparison. VM/CMW is slightly wetter than VM/S100. However, VM/S100 is more reflective and brings out a bit more metallic flake. You won't be sorry with either combo.
You could also try VM/EX for another "sun safe" combo. That combo has a deeper look than either S100 or CMW. It's my favorite combo for dark metallics.CarGlow said:But, you can use VM and CMW in the sun if you had to.
VM/EX-P can also be used in the sun. That combo has a very glossy look, however I think that these 2 products wind up cancelling out each other's best qualities. EX-P is very clear, but VM can make it less clear. VM is very wet, but EX-P can change that to a glossy look instead. It depends on the look that you are trying to achieve. My personal preference is to use VM with carnauba based toppers. For products like EX-P and UPP, I'd rather use a very clean looking base (Pro Polish or AIO) to retain the products clarity. Just my 2 cents.2drtahoez71 said:what about VM + EX-P?
