VacnBlo
Proctor
Hi All,
I just recieved my vacnblo in the mail, it looks pretty durable but, is there some sort of dolly you can by to wheel it around or do you have to carry it over your shoulder all the time. Also where do you guys keep all your Vac attachments since there is no bag or container to hold them
Thanks
I've had one for a couple of months now and absolutely love it! The more I use it the more I'm amazed with it's capabilities. It's made my engine detailing a breeze.:up
Regarding usage, I usually use the shoulder strap when vacuuming my engine, trunk or around the garage/house. When vacuuming the car interior I usually set it down on the seat making sure the exhaust is pointing away from everything so as not to overheat.
Good question on the attachments, I've been using a ziplock bag but would be interested in a slick suggestion too!
:welcome to Autopia
I have one but have never seen a dolly. I don't think you need one though. Its so light and small that its much easier to maneuver than a big ol shop vac. I just place it on the ground when I'm using it.
I keep the vac and accessories in a Rubbermaid container. Goes with me on every detail job.
Bret, Griots sells a little dolly for the VacnBlo if you're interested, but it's a bit steep and as you've mentioned the size/weight is minimal making it IMO unecessary.
I like the rubbermaid container idea, can you post a picture of the type you use?
maxshine, very cool setup and nice craftsmanship!:up
Quick question regarding the Vac n Blo Filter. Are there any tricks to cleaning the filter? What I've been doing is removing the filter and shaking against the garbage can outside. This makes for a dusty mess and I was wondering if someone has a better solution.
