using PC on new paint (Xirallic)
switerajaya
This is paint on the new Anniversary 'Vettes. Yes, I searched and did read the 3 threads that discussed this. Just that at the time of those threads no one had posted if they had used a PC to remove swirls. The dealer option for swirls came with the car. I am just not sure about using the PC to remove the swirls if the clear is thin or others say it could be a problem. In the cars current condition because of the lack of sun when these pics were taken, there are no apparent swirls. In the bright sun, you can find 'em if you look hard. But ofcourse, Autopians could. My co-workers think I'm being way to picky.
[had posted this question earlier with just a link to pic]
Pecs_McCoy,
I really like the color of your Vette!:bow :bow
I have a jet black BMW and have had great success with P21S Gloss Enhancing Paint Cleaner using a PC with a polishing pad. I would first try some GEPC by hand with a foam pad in a not easily seen place on your Vette. The GEPC is a mild polish that really leaves the paint glossy and slick. It won't remove all the swirls but it will make them much less noticeable.
I used to be very scared of the PC, but now after some practice, I would not be with out it.
Cheers,
My Black 7 Series
Thanks Amp99,
It's not a concern of PC usage that has me worried. It is because of earlier posts on Xirallic paint scheme that has me concerned if I do use the PC I can haze/cloud the effect of the Xirallic in the basecoat and effect the the red in the clear.
from Motor Trend
The paint itself is very special, using a "tintcoat" process with red Xirallic flake in a basecoat covered with a red-tinted clear coat. A synthetic silicate material, similar to that used in silicone computer chips, Xirallic flake permits a smoother surface than even expensive micas and aluminums found in most metallic automotive paints.
So until I hear back on some feelers I have out, I'll only try to hide the swirls I see. I did go buy some SEPC from the local Harley dealer so I am thinking just like you. Oh, btw, I've seen your gallery and luv those reflections. :xyxthumbs
