Using M105?
cheapshot
How are you guys using M105?
I have had great success, and I have had terrible flashing, gumming and dusting. I Believe this may be from working on warm surface, but not to sure.
My Process:
Flex DA /CCS orange
Pad priming; 1 or 2 mists FI, Rub M105 into pad evenly
Add 3 dots more
set machine speed 4.5
begin polishing no larger then 20"x20"
make 3 to 4 slow passes till dusting starts.
wipe clean.
use MF to clean pad while running the flex DA
add four more dots start new section.
I'll mist the pad every few sections, but I am not priming the pad with product like when starting.
I really want to dial in this process, but sometimes I get sick flashing and no work time before the panel is covered with dust.
