Using DAS blue pad for 2 products
Marceau
Hi,
Well I'm finished with the KLASS AIO using the blue DAS pad. it's awesome! :woot:
but now, I need to apply the P21S wax ... but I don't have a spare pad :\ What's the fastest way to clean the pad? Should I just soak it in water with some detergent?
After going thru 25 pages of search, I got tired :)
I clean my foam pads with hot water and a little dish soap. Let them soak for a while, and then wash/rinse them out. After that, just let them air dry.
Personally, I would just apply the wax by hand. It's extremely easy to use. Just wipe on and then wipe off. No need to apply it to the whole car, and then remove. Go ahead and do it all in one step, or panel at a time.
I don't have access to any other applicator or pad. I would have to order them from internet ... I need to apply it now ... that's the problem
Thanks.
A simple foam applicator that you can buy at any Walmart, Autozone, etc. would do fine. Do you have a mf towel? That would work too.
yeah, I have some buffing sonus MF. So I just fold it, to back and forth motion with the P21S and that's it?
Sounds too easy :P Thanks,
washing the pad takes 6 mins, be sure to carry soap for the pads with you all the time. a simple garden hose with soap= easy let dry in the sun! i do it all the time.
That's it! Just remember, less is better.
washing machine and dryer....Or just do P21S by hand...It takes so little time because it is like butter. And you dont have to wait for it to haze.
