Using Ardex Buster or MWB issue
XSNSX
Ok so i was experimenting with Ardex Buster and it works well for what it does but b/c of its honey base however the amount of pressure wash required to remove is quite intensive. So intensive, it's easy to miss some on the rim or brake caliper. MWB seems much more friendly to rims however isn't as aggressive as the ardex stuff.
When you all use any type of acid, what is your process? I'm just tad irritated because the Ardex acid made my brake caliper appear as if it had been bleached and not rinsed off...
I'm thinking I may have to spray acid on, pressure wash off after ~5 min, then re-spray rim w/ something like Purple Power which is alkaline...
any thoughts on this?
thanks a bunch
