User Friendly Light Cutting Pad for PC??
dschribs
Active member
Can you guys reccommend a user friendly light cutting pad for the PC?? I have Meg's polishing pads and wanted a pad to use when I need to "take it up a notch". I'll be using it with SSR 2.5 and Meg's #83.
Thanks!!
Both DAS and SFX work well on the PC, I find the DAS ones slightly less aggressive.
Ie Yellow SFX Pad V Orange DAS pad.
papi_jay said:
you got it backwards Richt if DAS Pads are less agressive then Yellow DAS = Orange SFX
DAS pads are less aggressive IMO, like I said.
BTW I have orange DAS pads and Yellow SFX pads?
are you listening to your bloody self talk ?
I don't know which one is more aggressive or not , I was going by what you said .
if a pad is LESS Agressive , then a higher cut pad would yield less results .
Therefore a Yellow DAS pad is has equal cutting power to an Orange SFX pad . YOU said the opposite .
Correction for you once more since you didn't get it according to your grading standard
Ie Orange SFX Pad V Yellow DAS pad < opposite of what you said ?
Correct ?
There is not an Orange SFX Pad!
DAS Cutting pad is Orange.
SFX Cutting Pad is Yellow
Both are cutting pads, but the more dense harder foam of Yellow SFX pad, seems more aggressive to me than the Orange DAS pad.
Yellow SFX Cutting Pad v Orange DAS Pad - The SFX has been more aggressive for me.
I think the Yellow SFX pad is more aggressive than the Orange DAS pad too. It's not only the nature of the foam; but the smaller diameter of the SFX pad too, IMO.
