1. i noticed quite a bit of vibration (6.5" pads, 6 counter) even at speed 4 so i didn't dare take it higher. is this normal? this leads to my 2nd q
2. is it necessary to have the pad perfectly centered? because my pads dont have a wedge nor a center hole to tell me exactly where the center is.
3. Am i supposed to start and finish with the pad on the paint? my first startup was in mid air and whatever i applied to the pad flew everywhere :rofl
4. after i went over some areas, i noticed occasional metal dots mostly on the front of the car. I'm guessing these are just chip marks?
5. I was going to apply zymol auto polish but it came out really runny so i threw it away. I also had a turtle wax scratch and swirl remover which i assume is just a filler so i didn't use that. I only applied nxt to the car using the pc... should i get some better products before i use my polisher again? i already have op, aio and sg in mind.
6. since there is so much vibration, can i polish at speed 4 and just make more passes to make up for speed 6?
Thank you all
Thank you all
