C. Charles Hahn
CCH Auto Appearance, LLC
Well, the time has come for me to update my tools for the upcoming detailing season. Years of customer details are starting to take their toll on my PC, so it's getting retired to "emergency backup only" duty. This way I don't wear it out completely, and I still have it available if I absolutely have to have it.
I've already concluded that I'm going to get a Flex XC3401 DA to replace it for the vast majority of the jobs I do, however I've also decided it's time to upgrade my rotary from the HF/CE unit I've been using. That's where this thread comes in.
The two machines I've narrowed it down to are the Flex 3403 VRG (the lighter of their two rotary offerings), and the Metabo PE12-175. I can't decide between the two, so I'm hoping some folks here have experience with one or both and can steer me in the right direction.
I know the Metabo is more PC-like in its controls (location of the switch and speed control), and has a lower starting RPM than the Flex. However, it doesn't have a trigger like the Flex does for feathering in panel edges or curved panels. Plus since I'll be getting used to the Flex DA, the Flex rotary will be set up basically the same in terms of how it is controlled.
Given that I'll have the Flex DA, I'm not so sure I care about the lack of lower speeds on a rotary -- by the time the rotary makes its appearance I'll have already maxed out the DA and likely won't be using the rotary at low speeds anyway. Maybe someone out there with a bit of experience with the machines would suggest differently, though.
Any thoughts, folks? Thanks in advance! :hmmm:
