There seems to be a lot of misunderstanding regarding AIO per another recent thread (which drifted off into KSG vs. Zaino). Therefore I wanted to share my thoughts with AIO have having used a couple liters of the stuff by now. And I'd be interested in hearing how others have successfully (or unsuccessfully) used this product.
As a swirls remover, it works okay. BTW, I've hear a lot of people say it isn't abrasive (it must say that on the packaging or something), but trust me, it has abrasives in it - if I use it to polish soft black paint, I can clearly see the tell-tale micro-marring of polishing abrasives...it just doesn't have a whole bunch of 'em.
As a last step product, it is also okay...but nothing like a pure sealant durability and slickness wise.
Where AIO excels beyond any other product I've found is in trim restoration and preservation - use this stuff to buff smooth and textured plastic (especially smooth) and you'll see what I mean.
Because it does not staim trim (actually, it improves it as above), it's great for polishing parts of the vehicle that are hard to tape off - like mirrors with both painted and unpainted plastic and even the vertical supports that typically separate the side windows on 4-door cars.
Because of its cleaning properties, it's also great for removing oxidation (ss paints) and with a PC and a cutting pad, is superb at removing water spots off of windows (and you don't have to tape off the moldings!).
