Undercarriage Cleaning & Care
togwt
The Old Grey Whistle Test
Your vehicle’s undercarriage; it’s what you don't see that silently awaits underneath your cars. Removing sprayed brine solution to protect your undercarriage is just as important as detailing the paint. Wheel wells, sub-frame, springs, fender well and all of the other black and gray parts underneath the body need detailing too.
After removing dirt, road grime, and etc with P21S® High Performance Total Auto Wash or Optimumâ„¢ Polymer Technologies - Power Clean- use a pressure washer (Kärchar Model K5.700) neutralise the effects of the alkaline sprayed brine solution on the suspension, wheel wells and the undercarriage (See also Road salt)
Never go underneath a car supported by the supplied jack - always use axle stands if you wish to work underneath the car. Always jack the car up at the manufacturer's recommended jacking points. Ensure the jack is in stable contact with both the jacking point (see owner's manual) and the ground. Always work on level ground.
A spray coating of Bilt-Hamber Laboratories - Dynax UC adds a durable long lasting protection, it also repels dirt, while enhancing any detail .It is possible to do this detail with the wheels on and just jacking the car up, but the ideal way is with the wheels off.
Metal parts use #0000 steel wool and Optimum Metal Polish and then apply a WOWO polymer sealant (Optimum Opti-Seal or Zaino Z-8 Grand Finale Spray Seal) for any rubber / vinyl parts spray with 1z einszett Tiefenpfleger -Vinyl-Rubber Care and Protectant
Kärchar K5.700 Pressure Washer- effortlessly cuts through dirt and grime and is convenient to use. Features include a long-life water-cooled induction motor that is light, powerful and energy-efficient. Features include a variable detergent regulator and innovative Plug 'n' Clean system - for quick and convenient detergent changeovers. Other features include Quick Connect hose, integrated hose reel and on-board practical accessory storage.
An impact-resistant, recyclable plastic casing effectively prevents dirt particles from damaging the motor and pump. A safety valve prevents pressure overload.
Long-life, aluminium three-piston axial-flow pump, corrosion-resistant, maintenance-free and energy efficient, a pressure switch control switches the motor on and off when the trigger gun is pressed and released.
Kärchar Model K5.93M
Specification:
• Totally enclosed by high-impact plastic cover
• Protection from dirt and damage, free of corrosion, impact resistant, recyclable
• Three piston pump (axial) technology, optimum efficiency, maintenance-free
• Aluminium pump - High life expectancy and good resistance against corrosion
• Safety valve - Protects the unit from pressure exceeding
• Motor-Stop - Machine stops, when gun is closed, relieves high pressure system and motor
• Large on/off-switch
• Easy to handle high-pressure hose with protective rubber
• Easy transportation and maximum mobility
• Water cooled motor for less weight, less energy consumption, extended life.
• Integrated high-pressure hose reel
• Comfortable storage and operation
• Plug 'n' Clean System for a quick and comfortable change between different detergents within a few seconds;
• Storage of accessories at the unit - no need to search for attachments
High Pressure Under body Lance
Kärchar angled spray lance specifically designed to clean those hard to reach areas under the wheel arches and the under carriage, compatible with all Kärchar domestic pressure washers.
Methodology
1. Thoroughly spray an undiluted citrus cleaner (P2IS Total Auto Wash) and let it soak in; remove by thoroughly rinsing with water. If you have a pressure washer available, fill tank with citrus cleaner and spray undercarriage (do not use excess pressure as water may penetrate crevices and seams where it cannot drain, causing corrosion), let it soak and then remove with plain water.
2. Spray undercarriage with (ValuGard Alkaline Neutralizer or Eastwoods Road Salt Neutralizer), which deep cleans painted surfaces to remove alkaline deposits and safely dissolves the alkaline salt particles bond with the paint so that they can be rinsed away. Allow product to remain in place for 5-7 minutes. All necessary safety precautions should be taken whilst using these products
3. Rinse vehicle undercarriage
Protection - apply a coating of Bilt-Hamber Laboratories - Dynax UC a high performance rust-preventive coating designed for application directly on metal surfaces; apply thin coats and allow each coat to thoroughly dry
Alternative product
1. Wurth High Build Underbody Spray produces a jet black, textured finish in wheel wells and on lower rocker panels. This spray will hide a multitude of blemishes and make old wheel wells look factory new. Provides permanent yet flexible protection against flying stones, rust, water and road salts
2. Wurth SKS Stone Guard matches OEM Factory applied stone protection on vehicles such as BMW, Fiat, Mercedes-Benz, Porsche and Renault; for use on door sills, front and rear body parts, mudguards, under bodies, rocker panels, etc. Stone Guard is a water based product and offers easy clean-up, its paintable and can be top coated with solvent based urethane or water-based top coats (available in Black or Grey)
Rust removal
Phosphoric acid may be used as a rust converter; by direct application to rusted iron, steel tools, or surfaces. The phosphoric acid converts reddish-brown iron oxide (rust) to black ferric phosphate (FePO4)
"Rust converter" is sometimes a greenish liquid suitable for dipping (in the same sort of acid bath as is used for pickling metal), but it is more often formulated as a gel, commonly called naval jelly. It is sometimes sold under other names, such as "rust remover" or "rust killer". As a thick gel, it may be applied to sloping, vertical, or even overhead surfaces.
After treatment, the black ferric-phosphate coating can be washed off, leaving a fresh paint surface. Multiple applications of phosphoric acid may be required to remove all rust. The black phosphate coating can also be left in place, where it will provide moderate further corrosion resistance [1]
Follow up with a rust protection aerosol can of ValuGard Rust Inhibitor and/or some Eastwood Heavy Duty Anti-Rust.
Neutralizing - washing the paint film surface with a slightly alkaline car wash concentrate and thoroughly rinsing will neutralize the contaminants and remove them from the paints surface Detailer's clay removes imbedded brake dust and other contaminants by encapsulation, thereby eliminating the primary cause
Treatment- by applying a suitable cleaner and then a rust inhibitor (POR-15® Products) it will arrest corrosion on contact without leaving a sticky residue that would attract dirt, dust or grime. Corrosion attacks metal by an electro¬chemical (galvanic) reaction with water as the catalyst. It penetrates the corrosion cells, emulsifying the moisture and separating it from the metal, leaving an ultra-thin barrier to protect from further damage.
Since most corrosion begins in crevices, (seams), it is important to have the capability to penetrate these crevices in order to form a protective barrier. Many heavier or more viscous products don't penetrate crevices, instead they form a `bridge', and while this may isolate the crevice from further contact with the electrolyte it does nothing to eliminate the presence of existing moisture or surface corrosion. Injection into a seam or crevice with an aerosol or spray eliminates this problem Por-15® Products Marine Clean
After the paint surface has been subjected to a chemical cleaning its protective layer (s) have been removed and the paint surface left without protection, so it is very important that a wax or polymer protection be applied immediately.
Rust Inhibitor Treatment
A three-part rust inhibitor treatment by POR-15®
1. Marne Clean â„¢ cleans and degreases in one application without leaving residues, noxious fumes or flammable solvents. Its water not solvent-based and it cleans without leaving residues, no other cleaner works as fast or as well. It makes petroleum-based cleaners almost obsolete because it can be diluted 5:1with distilled water, thoroughly rinse with clean water after completing your cleaning job.
2. POR-15â„¢ Metal Ready provides the best adhesion for POR-15® on any metal surface, including aluminium and shiny polished metal surfaces.
3. POR-15® is a high-tech, high performance rust-preventive coating designed for application directly on rusted or seasoned metal surfaces. It dries to an incredible rock-hard, non-porous finish that won't chip, crack, or peel, and it prevents rust from recurring by protecting metal from further exposure to moisture.
Rust Prevention
A British company Bilt-Hamber Laboratories has a new product - Dynax UC new high-performance anti-corrosion wax provides a touch-dry firm wax film that's virtually invisible, a low film thickness see-through protective shield. Its firm wax like film is rich in unique metal seeking corrosion inhibitors that stop existing and prevent new corrosion. It can be applied to bare metal or painted surfaces in fact anywhere where a discrete and powerful inhibitor is needed.
This product is aimed at those that want a see-through tack-free film that adds a lot of corrosion protection but preserves the factory look of the underside or lower panels, it’s removable too, so after winter it can be stripped if required, or left in situ and topped up every couple of years, or more if you wish; very easy to use.
Completely safe to use on the vast majority of paint coatings and is ideal where dark colored waxes or under seal would detract from the painted finish of vehicle bodywork or underside.
The touch dry tough wax film also provides mechanical protection to the protected surface too. The ideal product to provide high levels of protection during the winter months; to apply -clean any loose dirt, rust flakes or other debris and then clean with a power-washer, allow product to dry and then apply thin even coating.
Dynax UC / UB can be easily removed if required with simple solvent wipes or alkaline degreasers after the age winter months pass or left in place for prolonged protection.
Although Bilt-Hamber Dynax UC comes in a small aerosol pros may prefer to buy bulk (Dynax UB) and apply with a Mercury Pro + Sprayer - High-density Polyethylene (HDPE) their high quality Viton ® Seals guarantee fault- free operation and are is resistant to many different solvents and can be used for both high temperature and chemically aggressive applications, the double action (works on both pull and release) spray and can be adjusted from fine mist to a constant stream and also has stainless steel (chemical resistant) trigger spring fitted. Sizes available in 0.5 Litre (17 oz.) and 1 Litre (33oz.), available in blue, green, red, and yellow spray tops. They are simple to use and very efficient
