SuperBee364
Yesterday, I did a 2002 BMW 300 series sedan. He's a repeat customer from last year who actually listened to the car wash advice I gave him; he only used touchless automatics to wash his car ever since I polished it. That was a year ago. Imagine how surprised I was when the car showed up with nary a swirl to be found.
Since I wasn't going to have to burn a bunch of time correcting the paint, this was the perfect opportunity to really jewel the paint and match Ultrafina up against PO85RD. Especially since BMW clear is relatively soft... it's just the right softness. Not too soft to mar too easily, but soft enough to be very easy to correct and/or jewel.
So I did a quick once-over with purple foamed wool and SIP for general correction. I then followed this with Ultrafina on a white LC foam. It was just amazing how well Ultrafina worked on this clear coat. Four passes at 1500 RPM, and the Ultrafina was *done*. You could literally *watch* the gloss come up with each pass. It's counterproductive to keep working it after four passes. It's done as much as it's gonna do after four. The nice thing is that you won't hurt anything if you do go a few extra passes, you're just not going to gain anything.
The only thing I don't like about Ultrafina is it does have a tendency to sling once the pad is loaded. Even brushing the pad between applications doesn't help alot. I tried reducing the amount of polish to the point that it wouldn't sling, but then I simply wasn't using enough polish to get the job done. I'd still rather put up with the sling than the Menzerna dust, though.
I then did half the hood using Ultrafina a second, third and fourth time on an LC black foam finishing pad. The result was liquid shimmer.
I then did the other half the same number of times with another black LC foam pad using Mernzerna PO85RD.
On this particular clear coat, there was a large difference in shine. The PO85RD soundly beat the Ultrafina.
I then did the rest of the car using PO85RD and a black pad.
Keep in mind, though, that the PO85RD is useless as anything other than a jeweling polish. It simply can't be used as a compounding step follow-up like the Ultrafina can. Ultrafina just can't be beat in it's ability to bat clean-up after a compound and still leave a dramatic shine. But if you really want to go the extra mile, the PO85RD can improve on Ultrafina. Sometimes dramatically. It just depends on the clear coat.
No pics on this one though, darnit. I can't find the SD card for my camera.
Next car I do I'm going to test the Ultrafina on my favorite white finishing wool pad. I'm hoping for less sling.
Edit: Todd brings up a good point about the oils in PO106FF and PO85RD. To really get a good idea of how glossy the paint is after using one of these two polishes, you really need to get the oils off. Rydawg mentioned in a post last year that the best method he's seen for removing Menz oils is an IPA wipe. So I always do an IPA wipe after using any Menzerna polishes. The above gloss test was performed *after* an IPA wipe of the entire hood. After that, the gloss levels were judged according to my keen eye
with PO85RD winning.
