Got a call from a gentleman who was referred to me by the local BMW/Cadillac dealership. He had driven through something and since they don't do that type of work (or overspray removal), they suggested he call me.
I go out to look at the car and it appeared to be hardened tar that the owner of the car said had been there about 6 months. Some of it picked off with my fingernail, some wouldn't budge. Made an appointment for later in the week to remove it, seemed at the time it wouldn't be too hard to get it all off. Wasn't *that* much anyway, mostly the bottom 12" of the passenger side front fender and door, plus a little on the rear door and fender at the very bottom. I started off with some thinner to soften it up, only it wasn't softening it up. Plastic razor blades were bending trying to cut into the stuff and since it was a black car I felt best to not continue that route, too much risk of cutting the paint. Using my DA and rotary to try and get some heat into it to soften it up didn't do anything either. I was able to get about 60% of it off by picking at it but the areas where it had rounded off, it wouldn't budge because there really wasn't an edge to pick at. I got some out of the fenderwell and that is when I realized it wasn't tar but some sort of clear silicone sealer, like you would maybe use to seal the edges of a glass aquarium. Apparently the owner of the car had run over a tube of the stuff and thats how it got on the car.
I called a friend who suggested MEK, aka Methyl Ethyl Ketone, a product which my customer was aware of since he had seen it used to clean aircraft engines when he was in the Air Force so it is definitely some strong stuff. Nothing, didn't soften it a bit. I even tried wetsanding but as thick as it was in some areas, the risk of oversanding the surrounding paint was too great and even 2000 grit wasn't making any real progress. I then called a buddy who owns a body shop and he said he felt I had done everything I could to remove it that wouldn't harm the paint and that refinishing would likely be the only real solution.
In the end, I kept picking at what I could, ended up getting about 75% of it off, but the really thick stuff along the bottom molding wouldn't budge. Rewashed the car to make sure I didn't leave any thinner or MEK behind, then polished with D300 and D301 (using the appropriate Meguiar MF pads) and called it a day. My customer was pretty happy, said the improvement was very noticeable and that it was something he could live with because he really didn't feel like spending $1000+ on refinishing that side of the car. I ended up not charging full price for my time because I couldn't it off completely. I got about 75% off so I charged him about 75% of what I normally would have. I'm glad my customer is happy but it kind of bugs me I wasn't able to completely remove the stuff for him.
Anyone else run into something like this?
