Ugh!! I used to Much SG
layer3switchguy
Hi folks,
Looks like I put down a bit to much Klasse SG today. Have some streaky areas on my hood. Can anyone suggest what I can do to fix this? I do have Sonus Acrylic Glanz, will that help?
Thanks in adavance for any advice.
L3
i guess a qd might help a bit. maybe if you apply a little bit of SG to the car again, then buff it off it might help. i often hear that applying a bit more of the original product can assist in removal.
good luck. i want pics when you finish.
I've had real good luck simply reapplying SG and removing it immediately on areas I missed or that lightly streaked.
JDookie said:
Would it help him if he applied the second coat with a mf bonett on the pc?
Shouldn't be necessary . . .
Simply reapply the SG (lightly), work it over a 2' x 2' area, then immediately wipe off (before SG dries). This has always worked for me.
