Drying has never worked for me. I use a waffle weave from Autopia Car Care. So now I am considering a 2 towel method. I plan to throw in the Cobra Supreme 530 (fluffy). Should I use the 530 on the first pass or the waffle weave on the first pass?
Hmmm...I cannot help you with your exact question, however, I usually blow dry with an air compressor first and then just finish up with a waffle weave.
if you use just the hose (or in my case a firehose nozzle turned all the way to one side with the blooming pattern) and sheet as much water as possible, you should only have to use one waffle weave or microfiber drying towel...
Sheeting method followed by waffle weave works well for me. One good size waffle weave does most cars, but you may need another depending on the size of the vehicle.
A compressor or blower works well for getting in the cracks and making sure everything is dry before proceeding with polishing or an LSP.
