Two questions
hkross
My car looks realy realy hazy anybody know what the cause of that is. Right not i have meguairs cleaner wax on it. I washed it off last night a a power wash station. Just cause i needed to clean my tires to put my hub caps on. And had more time left. Also when I have washed and waxed my car i have trouble telling if there are dents in the car. From the look in my sideview it does but doesnt when i get out anybody know why that is. Thanx alot.
some door dents & dings can only be seen on angles. Go to the corner of the car and get down level with the car. looking from the angle you will be able to see more dings & dents, then you will head on.
With the haze from your wax, how much are you using? are you sure you removed it all?
Try some QD on the car, see if that will remove the haze or left over wax.
You might also want to start over and wash the car with dawn then polish & wax.
when waxing remember that less is more. no need to use a bottle of wax on a car.
IT could be a few things. One, your car could have oxidation on the paint, which will cause a hazy appearence.
Or you had a polish on your car that was too abrasive. I tried ProWax Duz-all on one panel of my truck which had been previously polished with Meguiar's #9. I could tell (as well as everyone else I showed) that there was a haze across the Duz-All panel. It caused this haze because it was not as fine an abrasive as Meguiars #9.
