Tutorial on car washing
QBridge
I looked at the articles on this site. I didn't find them to be helpful. The articles are bits and pieces and none actually describe the full process of washing a car using all those products mentioned in the articles. Basically they're written for people who know what they are doing and not someone who is new to things like waxing, clay, polishing whatever. I understand that they are just articles and not tutorials.
Is there a tutorial that covers the entire process of washing a car, using clay and polishes, detailing and waxing? I didn't find a tutorial like that here. Maybe I missed it.
DavidB said:
Sorry you didn't find the information helpful. You might find my book more useful.
http://www.guidetodetailing.com/articlenoheader.php?articleId=58
Not to be rude or an ******* but does the process of washing a car, using clay, polishes, detailing and waxing require an entire book or more than 2 or 3 pages of text?
I now I understand why there is no tutorial like the one I'm talking about. People have to buy the book. It's a business, I completely understand.
I'm sorry if I offended you.
QBridge,
It's not a business at all. The e-book is completely FREE
QBridge- Welcome to Autopia!
I'm one of the Autopians most interested in the wash process (as opposed to other aspects of detailing). It really *would* require an extensive effort, and more than a few pages of text, for me to prepare a thorough tutorial on how to wash. I was a teacher (college level) who prepared my own learning materials, so I do know whereof I speak.
The big challenge with washing is to move the dirt off the paint without marring the paint. Much of the dirt is abrasive, and if even slight pressure is applied to this dirt while it is moved over the paint, scratches/"swirls"/"spiderwebs" will result. And that's just one aspect of washing the primary areas of the vehicle. Doorjambs, wheelwells, wheels, etc.- every area that requires a slightly different approach could take an entire multi-page write-up.
If I could spare the time, I'd enjoy writing up a guide to washing, but my posts on how to wash using my "extreme wash method" took an incredible amount of time as it was. Look in the Hall of Fame forum to check it out (my old link doesn't work at present). It's a "how to wash" that will work great if (big "if") the vehicle isn't too dirty and you have a good coat of wax on it.
EDIT: See if THIS LINK works, I think it will.
mystickid said:
QBridge,
I'm really sorry. I thought I had to buy it. The book had the same information as the articles though and there is no full tutorial.
Here's a quick version of what I did (before getting some other
stuff)....
Stuff you'll want to have for the wash (this assumes you have access to a
working garden hose and a "clean water supply):
1. car soap
2. 2 buckets clean water; one for the car saop/ water mix, and the other
with plain water for pad/ mitt rinsing
3.at least 2 wash mitts or pads (cotton or wool prefered
4. semi soft bristle brush for wheels, tires, wheel wells, and rocker-panels.
5.apc (all purpose cleaner), or "tar n' bug remover" if needed.
6. 3-4 high quality towels (perferably waffle weave microfiber towels
1. Hose down wheel wells, tires, and wheels. Next wash wells, tires, wheels,
and rocker panels with your fave cleaner (usually a good car soap or APC will do.
After that, rinse these areas. For tar, I suggest using a good prep-solvent
or one of the OTC products. don't rush this; let the product(s) work for you.
2. Hose down the car to remove the loose dirt..
3. In a bucket, mix a portion of your fave car soap with water (read the directions)
3. Agitate mixture, and apply to the paint with a clean wash mitt, or pad (wool or
chenille covereed pads/ mitts seem to be the best). Start from top of car, and work
down: half of roof, half of front glass, half of hood, half of rear glass, half of decklid.
After that, wash upper fenders, upper doors, and upper quarterpanels. Use your
other clean mitt or wash pad to cover the lower fenders, doors, quarterpanels,
bumpers, and exhaust tips. Rinse off the soap from the washed side. (when I refer
to the "lower half", I am refering to those area below the "trim" or "moulding" line;
the heaviest concentration of dirt and grime is usually in these areas, so it's best to
use a seprate mitt or pad to tackle this). Also, be sure to constantly rinse, and
inspect the pads/ mitts for any particles that may get stuck in there. remove these
particles as often as you can so they don't scratch the paint
Do the same for the other side.
For the rinse, the most effective method most of us find is to remove the nozzle
off the garden hose, and allow the water to pour out (this is called the "flood method").
Start from the top, and run the water down the front glass, down the hood. Repeat for
the back of roof, don the back glass, and down the decklid. Finally, run the water
slowly along the fenders, door glass, side mirrors, doors, and along the quarter
panels. You may find that all the water has not come off, but with practice, you
should be able to reduce the amount of water left on the car to wipe off.
To remove the leftover water, dab with a damp ww towel (I personally find this
does a better job of pulling off the water than just using a dry towel.)
Inspect, and dry off any missed areas as needed.
When done, you move on to the next area to be addresses\d, whether it be
paint cleaning, polishing or waxing.
That's a very good description. I've done the same things you mentioned but I usually wash the car from top to bottom. I rinse it first. Than start to wash from the top down rinsing and washing as I go. I found that it's better to leave the water running on top of the car and wash at the same time so that the dirt washes away and doesn't dry. I use whatever soap I left have to clean the wheels. A car wash for me has always been just soap and nothing else. Never waxed or used clay or polishers or even tar and bug removers. That's is why I was looking for a tutorial that would go through a full process. I guess I just have to get the car as clean as possible and than go on to clay, polishing and finally waxing.
I found this to be of help.
http://www.advance-auto-parts.com/english/youcan/html/ccr/ccr20040901wh.html
All I need now is the products.
I pretty much use this same method but make sure to rinse each wheel/wheelwell before moving on to the next one, then rise the whole car before working on any paint and use fresh soap for the paint as well
you want to work in the shade if possible or at least partial shade
