mix it 2 parts pro to 1 parts OC2.0 or with equal parts Xylene (but i like mixing with 2.0 instead so your diluting with another coating, not with thinner). If it gets on the glass, wipe it off, really no reason to worry about it on the glass at all. Work @ very low pressure (do some testing with opti seal to get the hang of it). Stay 10-14" off the car, I've found that shooting a light amount over 2-3 applications is ideal and gives you the best coverage. Use vertical motions during the first application, horizontal on the 2nd, horizontal on the 3rd). As you spray, you'll develop a cloud around the car, you'll want to prevent that cloud from settling back on the car (making spots-I learned that the hard way) with a shop fan on low or some form of exhaust fan. Airbrushing is great because it speeds up application, there are never high spots and if there are, you can simply just blow air through the trigger to knock them down.
