I agree with Accumulator. GM cars from that era had side terminal batteries, which were excellent, but had skinny battery cables, both positive and negative and attached the ground cable to the alternator bracket, rather than the engine block itself. My El Camino got traded in back in 1993 because of slow starting concerns nobody could find. The ground cable was very warm when cranking, a sign of high resistance. I replaced the ground cable with a thicker one from a GM truck, cleaned everything well, both positive and grounds and bolted the cable directly to the engine block. It's been OK for the last 21 years, thru 3 or 4 batteries, so I think it's fixed.
Bill
