Trim & Molding Care Made Easy
AutopiaTech
Moderator
There is no question that detailers and car care enthusiasts have an eye for detail (pun intended) more so than those involved in other hobbies. Like the name implies, detailing is all about the details. No detail, big or small, should be overlooked in a detail. So when I walked outside for a lunch break the other day and saw a shiny GMC Canyon in the parking lot with dull, faded tires and exterior trim, I knew I had to do something about it.
To bring back new life to the tires and the exterior trim, the obvious choice was Wolfgang Exterior Trim Sealant. If you've spent more than sixteen minutes on any given car care discussion forum, there is no doubt that you've heard people rave about Wolfgang Exterior Trim Sealant, often referred to as "ETS" or "WETS." If you're forum-savvy, surely you know that when a product receives its own abbreviation, it definitely falls under the vaunted classification of being known as the good stuff.
Wolfgang Exterior Trim Sealant is a hyper-concentrated sealant for your tires and exterior trim. Application is straight forward and you won't have to spend hours searching Youtube for videos explaining how to properly use it. Wolfgang Exterior Trim Sealant can be used on all color exterior trim and just like other Wolfgang car care products, less is more. Don't stop with your tires and trim, because Wolfgang Exterior Trim Sealant can also be used on wheels and other metal surfaces.
It only takes seconds for your exterior plastic, rubber and vinyl trim to look new again. Wolfgang Exterior Trim Sealant dries to the touch and each application lasts several months.
Wolfgang Exterior Trim Sealant also works great on hard plastic door handles.
The difference is clear.
When used as a tire dressing, Wolfgang Exterior Trim Sealant provides a low-gloss, natural finish. Because Wolfgang Exterior Trim Sealant is packed full of polymers, it will cling to the tire's surface, providing weeks of durable protection.
Just like with the trim, the difference is clear.
No greasy, shiny finish is left behind with Wolfgang Exterior Trim Sealant.
Wolfgang Exterior Trim Sealant makes restoring and protecting exterior plastic, rubber and vinyl surfaces quick and easy.
Autopia Trim & Molding Care
:autopia:
Bought 8oz on BOGO sometime back, and it really works wonders on trim. On my mom's car, it kept trim at a nice satin finish that was very easy to clean up, and even prevented fresh road paint from adhering to the trim, making it easy to remove with an old MF towel.
I don't like it that much on tires though as it doesn't spread all that time and I get the feeling that I'm wasting product; I prefer BF's tire gels (single coat).
