tree sap removal
I would start by wetting the surface, spraying on a mild citrus degreaser, and letting that sit for a few minutes to soften the tree sap (do this in the shade, and DO NOT let the degreaser solution dry on the car!), rinse the car off, and then clay bar the surface to remove the tar.
Isopropyl alcohol with microfiber. After you get it cleaned off, clean the windows with window cleaner, and go over with razor blade to make sure nothing was missed.
John
John
x2
DO NOT use clay until it's completely cleaned off because it will marr.
