Jakerooni said:razor blade.
Jakerooni said:ugh.... Why must people make it more difficult and entirely way more expensive then is ever necessary??? The easiest way to tackle anything on glass is a razor blade. Not chemicals or magic anythings... Just a plain old razor blade. You won't scratch the glass (mirror glass excluded here) and you'll get a better result quicker than anything else out there with almost zero cost... I'm not trying to bust balls here but I go out of my way to make absoultly sure I never post bad information. While the answers I give are never the only answers, but in my experience they are usually the fastest and most economical ways possible. and are always solid advice in any detailing cirrcumstance.
....I can't speak for others but my experience using razor blades for the past 25+ years to remove various stickers, hard residue, etc. on glass has been just the opposite. In my case, it's convenient, easy and a readily accessible item I use for multiple tasks (I always have one around). In most scenarios I can simply scrape down the window and be done in a couple of minutes. The only time I even need to work a small area is when the blade sticks and requires a couple of quick jabs to work the material loose.Anthony A said:The Magic Erasers can be had for around a dollar and using one of them is faster than a razor blade. Just wash the glass and than rub a damp eraser on it. Sap, spots, what ever comes right off. The razor blade requires working small sections at a time and is time consuming IMO compared to a Magic Eraser. Having used both many times I can say I would use the eraser any time on glass instead of a blade.
Just curious have you tried the an eraser? First time it was suggested to me I laughed and rolled my eyes. Than I tried it and was amazed at the ease of use and results.
