I did hundreds of touch ups to automotive paint way back when I was an Apprentice Painter, and then a Journeyman Painter..
The only brush used back then was made by Mack and looks very close to this one ---
https://www.amazon.com/dp/B000RLNPM...olid=2VT1YKJ8BB78D&psc=0&ref_=lv_ov_lig_dp_it
You have to - learn - how to use it, so practice first..
What I like about this brush is that once you get it wet with lacquer thinner, it really gets even sharper, all the way down to the tip where you want it that way..
With this brush, once you learn how to use it correctly, you can put a little paint into the chip very precisely.
What is good about product like Dr. Colorchip is that it is a lacquer based touch up, so it won`t have an issue with today`s paint which is probably all water-based..
So, if you accidently put too much paint in there you can quickly blot it out and start over..
I still have the swordbrush I bought around 45 years ago and it still works great.. It looks just like the one in the Link I provided above..
Dan you mentioned - Blending - there is no way to ever really
Blend a touch up with the rest of the paintwork without first -
feather edging - all the paint around the chip just enough to remove the edge, and then spraying paint back into the area, overlapping the chip, and then coming back later and carefully compounding the area all flat..
And then, if you really want to go to all that work, you must understand how to BackTape with tape and paper, all around the area/s so when you spray the paint, you dont leave paint build up - edge/edges - on the panel where you tape and papered it off...
So, getting back to using the correct brush, it is the only accurate method in my experiences of putting just enough paint into chips.. The rest of the work afterwards to try to smooth them down, (because sometimes the object that caused the chip raises the paint all around it when the whatever it was hit that spot), may or may not work perfectly.. Sometimes, if the chip itself was not cleaned good enough so the paint can hold better, or the paint was not applied in layers and allowed to dry properly, etc., one can actually remove the chip paint repair, by compounding over it..
In the days of acrylic lacquer and acrylic enamels, whenever you used the appropriate paint for them with the appropriate thinner or reducer, it actually - melted - down into the paint (because it was the same kind of paint), and that always helped the chip to adhere tighter and not come out.. But those days are gone..
I don`t know what today`s water based Painters do for this ; perhaps, stop by a good automotive paint shop and see if you can talk to the oldest Painter there and see how he does it??
Dan F
