Took me long enough
picorrect
I really think it'll help the application of Zaino and hopefully make the Z5 work a little better at removing surface scratches.
So if you are using Zaino with the PC, what pads do you use?
Do you use the PC for application, removal, or both?
Sorry to be a P.I.T.A but I want to order it today and wanted to know what to get.
You waste too much product using a machine, plus it is soooo easy to apply and remove......
I doubt you will have any better results with Z5 and a machine. The formula is non abrasive.....
<em class='bbc'>Originally posted by DETAILKING [/i]
<strong class='bbc'>You waste too much product using a machine, plus it is soooo easy to apply and remove......[/b]</blockquote>This has not been my experience. I use my PC to apply Z1 (since it calls for circular motions, I figured I'd give it a try). I used <strong class='bbc'>much[/b] less product with the PC than with the supplied Zaino applicator. It takes a bit of Z1 to get the PC pad damp for the first panel, but after that, it only takes about a half-dozen "dabs" of the bottle around the pad to do another panel. IMO, I get better coverage and a thinner coat (which leads to easier removal).
YMMV, of course, but I've had good luck with it. Caveat: I haven't tried the PC for removal, and I still do Z2/Z5 by hand (although with a foam applicator rather than terry).
Tort
Usually it takes a lot of product initially to saturate the pad. I hardly use any Z1, I can easily get 15-20 coats per bottle.
