togwt
The Old Grey Whistle Test
{Knowledge Management} - Treating experience as a shared asset} Science meets Aesthetics; I contribute to these forums to pass on more than five decades of detailing experience along with three decades in the chemical industry to its members in not only the “How it works’ but “Why it works� and the chemicals involved with “What works “and in turn be educated by them. Because I’m passionate about I do and care about making sure detailing is a fun and rewarding experience for the enthusiast.
Automotive original equipment (OEM) technology is becoming more and more complex requiring educated and skilled technicians to work on them. As the materials used are constantly changing we must maintain our knowledge base and utilize the correct products and application methodologies to keep up with emerging technologies. It is very important to be able to recognise the various finishes and materials used as they all require different methodologies and products for proper care and maintenance.
[The articles posted are extracts from a series of 150 in-depth technical articles that make up “The Art and Science of Detailing “a full list of which can be found on my Blog
Article Revisions / Updates
The advent of new materials is why it’s so important to monitor the industries new products, chemical technologies and ideas that are constantly being introduced, as are the techniques for applying them, hence all of the in-depth articles and these extracts are constantly up-dated and will be revised periodically
Techniques Suggested
Detailing isn't rocket science, but any aspects that aren't intuitively obvious need to be researched and thoroughly thought out. There is no `one correct way' to apply a product; the way detailing products are customized, are what each individual finds give them their desired results, which may or may not be in accordance with the manufacturer’s recommendations.
Using the same application methods and products of one individual may or may not give you the similar results; but it’s always best to adopt your own methodologies by experimentation with different products, after all that half the fun of detailing
The application methods set out here have been adapted for special use and may not be the same as those recommended by the product manufacturer, and you may experience different results from those stated. If in doubt follow manufacturer’s recommendations. The price you’ll pay for product / methodology experimentation is knowledge and firsthand experience.
Some of the methodologies are controversial as they do not conform to popular practices, but as with all things allow common sense to prevail. I’ve found that some myths are deliberately perpetuated by product manufacturers as negative marketing and others are just common errors of judgment
I would strongly suggest that you verify any information that I or anyone else shares with you. It is the individual’s responsibility to confirm the information supplied and apply it to their own particular situation.
List of article extracts and hyper links
Guide To Detailing
http://www.autopia.org/forum/guide-detailing/136449-microfiber-100%-cotton-towels.html
http://www.autopia.org/forum/guide-detailing/136448-identifying-foam-pads-abrasive-qualities.html
http://www.autopia.org/forum/guide-detailing/136447-repairing-stone-chips.html
http://www.autopia.org/forum/guide-detailing/136408-layering-spit-shining-waxes.html
http://www.autopia.org/forum/guide-detailing/136435-paint-surface-scratches-cause-effect.html
http://www.autopia.org/forum/guide-detailing/136403-ultra-violet-uv-radiation.html
http://www.autopia.org/forum/guide-detailing/136421-proper-finished-leather-cleaning-care.html
http://www.autopia.org/forum/guide-detailing/136387-detailer%92s-clay-vs-decontamination.html
http://www.autopia.org/forum/guide-detailing/136409-matte-satin-finish-paint-body-wraps.html-
http://www.autopia.org/forum/guide-detailing/136406-why-use-wax-top-polymer-sealant.html
http://www.autopia.org/forum/guide-detailing/136405-paint-density-hardness.html
http://www.autopia.org/forum/guide-detailing/136465-glass-cleaning-process.html
http://www.autopia.org/forum/guide-detailing/136466-product-reseach.html
http://www.autopia.org/forum/guide-...s-look-when-purchasing-micro-fibre-towel.html
http://www.autopia.org/forum/guide-detailing/136477-wipedown-wipe-down-process.html#post1447598
http://www.autopia.org/forum/guide-detailing/136494-towel-cleaning-care.html#post1447725
http://www.autopia.org/forum/guide-detailing/136495-air-conditioner-cleaning.html#post1447731
http://www.autopia.org/forum/guide-detailing/136496-convertible-roadster-fabric-top-detailing.html
http://www.autopia.org/forum/guide-detailing/136497-carpet-cleaning-care.html
http://www.autopia.org/forum/guide-detailing/136516-stain-identification-removal.html#post1447914
http://www.autopia.org/forum/guide-detailing/136530-detailing-door-jambs-door-shuts.html#post1448085
http://www.autopia.org/forum/guide-detailing/136531-foam-pads-i.html
http://www.autopia.org/forum/guide-detailing/136534-detailing-physically-challenged.html#post1448095
http://www.autopia.org/forum/guide-...-decontamination-remove-washing-will-not.html
http://www.autopia.org/forum/guide-...r-coat-thickness-paint-removal-polishing.html
http://www.autopia.org/forum/guide-...ewly-painted-non-oem-vehicle.html#post1448362
http://www.autopia.org/forum/guide-detailing/136573-what-polish-pad-combination-use.html#post1448466
http://www.autopia.org/forum/guide-...y-disposal-aqueous-solutions.html#post1448476
http://www.autopia.org/forum/guide-detailing/136608-removing-water-spots-marks.html#post1448627
http://www.autopia.org/forum/guide-detailing/136609-engine-bay-detailing.html#post1448628
http://www.autopia.org/forum/guide-detailing/136612-should-i-use-dawn-wash-my-paint.html#post1448633
http://www.autopia.org/forum/guide-detailing/136613-nanotechnology-coating-products.html#post1448634
http://www.autopia.org/forum/guide-detailing/136637-paint-surface-cleaners.html
To be continued...
Health & Safety and Well Being Related Issues
http://www.autopia.org/forum/guide-detailing/136515-personal-protective-equipment-ppe.html
http://www.autopia.org/forum/guide-...s-alleviate-repetitive-strain-injury-rsi.html
http://www.autopia.org/forum/guide-detailing/136634-detailing-health-risks.html#post1448766
To be continued...
Detailing Business Management & Marketing
http://www.autopia.org/forum/detailing-business-management-marketing/136437-business-marketing.html
http://www.autopia.org/forum/detail.../136439-essentials-starting-new-business.html
http://www.autopia.org/forum/detail...ng/136438-becoming-professional-detailer.html
http://www.autopia.org/forum/detail...ng/136474-marketing-internet.html#post1447579
To be continued...
Copyright © 2002-2011, TOGWT® (Established 1980) all rights reserved
Guide To Detailing
To be continued...
To be continued...
To be continued...
http://www.autopia.org/forum/welcome-greeting-center/] Authors Profile [/url]
