Greg@DetailedImage
As a professional detailer you most likely spend countless hours researching the best techniques and products to get the best results possible. The products and processes you use show that you are concerned with both safe and effective detailing work. You generally takes more time, invest more into your products and thus charge more for your services. The quality of your work is the backbone to your business and it defines you as a detailer. After completing a quality detail the results are self evident to someone with a trained eye. Unfortunately, to the average person the results from a high quality detail may be hard to distinguish from a local car washes detail job. As we all know the majority of vehicle owners have very little understanding of what truly defines high quality detailing. Therefore it is important to not only do high quality work but to go the extra mile so the customer also perceives that you do the highest quality work.
We recommend adding some additional quick and easy steps to your routine that should improve the perception of the results. Here are some of the steps we suggest you do to further distinguish your work from other "detailing" services. Probably the most obvious and popular example is applying a scent or air freshener to the vehicle. It makes the car smell fresh and helps the customer remember the detail for days and weeks to come. Brush the fibers of the carpets and mats all the same direction. This makes the carpets look totally uniform and more like new again. Straighten all the vents so they are at the same tilt both up and down and left to right. This may seem like a small detail but it makes the detail look more symmetrical and professional. The same concept applies to the seats, straighten them so they look symmetrical and uniform. If there is a long seat belt (typically the middle seat) that does not retract, we recommend folding it up and straightening out all the other seat belts. Following these steps helps increase the "wow" factor and makes photos of your detail work look even better. These simple steps do not necessarily directly improve the quality of your work, but the customer should further notice the improvement from the detail and thus perceive an even higher quality detail. Ultimately we hope these steps will help you make a greater impact on your customers and enhance your business.
Please feel free to post some additional steps you take to add to this list. Thank you for reading and I look forward to posting more articles like this!
