TID MEMBER SPECIAL!!! NEW 5.5 Inch Classic FLAT Pad Pre-Order SUPER Discount!
Todd@RUPES
Just a regular guy
We have heard the requests for our premium line Hi-Gloss line to be made in 5.5 inch pads, and we have listened. These pads have been in the works for a long time, the cutting and manufacturing has been carried out to perfection by our friend's at Lake Country, and they will be here next week.
These pads come with all the great features you can expect with our Hi-Gloss pads.
A back cut and raised attachment point allows for a full sized 5 inch backing to be fit to the pad for optimum efficiency and easy centering.
The polishing face of the pad features rounded edges that reduce holograms and marring from the sharp leading edge.
Our exclusive Constant Pressure Technology second layer of instant rebound foam. This absorbs off axis motion and allows the pad to contour to curves and bends in the panel shape, as well as allows for the polisher to be titled while maintaining a flat polishing surface.
Retail Price is $8.99
Introductory Price is $7.99
And the TID Pre-Order Discount is 20% off of the Introductory Price.
This means that these $8.99 pads are available for $6.40 dollars at pre order, or almost 30% off!!!!!!!
How do you pre-order?
Simple.
Sign this thread before the pad's are in stock (est. Wednesday).
You will receive a code for 20% off of the pads for a total of 30% off, as many as you want.
You are NOT obligated to buy, but if you are interested you should sign up.
The coupon code will be valid for 3 days after being sent out and is only valid for the NEW Hi-Gloss 5.5'' Classic Flat Pads.
Yes!!! I have the dimpled constant contact pads in 6.5 inch and that pad is working great on the Mustang I am currently correcting but I can only work on the big flat areas due to the size, this is great news as I think 5" is the most versatile size and my Flex rotary will not heat up as fast.
Sign a brotha up.
