kimwallace
Clay is a great tool to help achieve the best paint finish possible. It can however create additional problems if not used carefully.
Clay is used to remove the embedded contaminates in paint that cannot be removed by washing or polishing alone.
In my opinion when clay is used to remove tar, bugs, paint specs and other surface contaminates that can be cleaned off with a soap or solvent, the risk of scratching the paint is greatly increased.
Tar can contain particles of dirt and small pieces of stone and who knows what bugs eat. Some of the paint specs, especially road paint, can contain abrasive particles that are harder than the paint on a car.
This is the claying process I use to help me reduce scratches and still achieve a smooth finish:
1. Wash and dry the car
2. Examine the paint for tar or other surface contaminates
3. If tar is present, use a tar remover to clean it off.
5. On Base Coat/ Clear coat finishes, Lacquer thinner or Goof-Off can be used to remove most paint specs. Be careful to keep it off of the plastic trim pieces because most of these are single stage paint and can be damaged by these two solvents.
6. Wash the car again if needed, to remove traces of the solvents used
7. If the paint is badly oxidized, clean the paint with a product like Poorboy’s Pro Polish, Klasse AIO or Meguiars Dual Action Cleaner Polish. Otherwise the clay will load up and not work as effectively.
8. Clay the car starting at the top and working down. (There are usually more contaminates on the lower parts of the car)
10. These are just my opinions based on my experience. I am sure there are many others but this is what works best for me.
I saturate a cotton cloth and wipe the car down … let sit for a few minutes and wipe off with a dry cotton cloth. This method is inexpensive and safe for the paint.
4. Use a bug remover or diluted APC to remove bugs.5. On Base Coat/ Clear coat finishes, Lacquer thinner or Goof-Off can be used to remove most paint specs. Be careful to keep it off of the plastic trim pieces because most of these are single stage paint and can be damaged by these two solvents.
I use Clay Magic and Meguiar’s Final Inspection as a lube. After much experimentation, this combination is what works best for me. Everyone’s technique is different so different combinations of clay and lube may work better based on the pressure applied and other factors. I also divide a 200 gram clay bar into 6 or 8 pieces so if it gets dropped or contaminated, I can pitch it and grab a new piece. I clay one or two panels at a time and wipe off the remaining Final Inspection with a Micro Fiber Towel. This also removes any smudges from the clay, leaving the surface ready to Polish and Protect.
9. On many car including new, it is only necessary to clay the areas that do not feel smooth.10. These are just my opinions based on my experience. I am sure there are many others but this is what works best for me.
