I have a small electric one and a larger gas one.
If you're thinking about a gas powered one, Honda makes very reliable motors. One version is for the home market, the other version is the commercial market (GX).
Pumps vary from low end (comet), middle (national/general) and high end (cat).
Carriages can be steel or stainless.
By combining a variety of the above options, prices can range from approx. $450 up to $1500 for a really good home unit 6-8 hp, Gx (commercial) honda, cat pump, stainless cart, psi 2700 - 3000. Those would be Can. dollars so your american values would be less.
Other fellows have mentioned holding the nozzle farther away lessens pressure and using a wider fan lessens pressure.
A variable stream tip (about 80 bucks) can increase the power of the unit too.
Cheaper electric ones are virtually throw away units. Buy one for 120 bucks and when it breaks, toss it. A shop would charge 80 bucks just to look at it.
An adequate honda unit for home use might run 6 - 800 bucks and they are handy around the house and those honda engines always start really easy.
-John C.
