Thoughts/ comments?
scottabir
This was taken from another post from a thread on xceedspeed.com:
This was taken from Jax Kar Wash's website:
Research Study Shows That Hand Washing of
Cars at Home is Harmful to Automobile Finishes
The International Carwash Association working through a special Carwash Research Foundation Grant to the University of Texas at Arlington, Texas, has conducted extensive car washing tests this past year to determine the effect on car finishes by comparing various car washing techniques ranging from professional car washing to the bucket and sponge used by many auto owners.
Hand wash jobs are extremely harmful to automobile finishes - Tests conducted by the University of Texas to compare surface disturbances showed that a single home hand wash on an automobile can produce scratches that penetrate as deep as 1/10 of the total thickness of the automobile's paint.
These test findings at the University of Texas substantiated tests done over ten years ago by the Technical University of Munich, Germany, in association with Mercedes-Benz, which at that time showed that similar damage was done to an automobile when using detergent, low water volume commonly found in hose nozzles at home, buckets of water, sponges and towels used in the average home car washing.
Specific scientific tests at the University of Texas further showed that hand car washing can produce so many marks on a car's finish that they cannot even be counted. The tests showed that in all hand washing temperatures, surface reflectance readings steadily declined, with some hand washing techniques being considerably worse than others. By contrast, when cars were washed by professional full service car washes, there was virtually no change in the surface reflectance or shine readings.
The tests showed that the average backyard hose is not able to supply enough water along with the detergent action to avoid damaging the car's finish. The most harmful method of washing cars was found to be the special "car wash" brushes that hook on to a garden hose and are purchased from local hardware stores or automotive supply dealers. The use of this type of brush with the low water pressure that comes out of the garden hose is the most destructive on the finish of an automobile. The tests also showed that techniques used at professional car washes are virtually harmless to automobile finishes. Findings from the University of Texas research study indicate that with the large amounts of water and specialized detergents used in professional car washes, sophisticated gloss and reflectance meter readings from new finishes used on automobiles were virtually the same before and after the equivalent of several months of normal washings in a professional car wash.
The professional car wash is able to provide and use tremendous amounts of water along with specialized detergents and appropriate mechanical action from cloth pads and curtains which the backyard hose and bucket hand car wash is not able to supply. This important and interesting research study performed by the University of Texas found that today's automobile owner is much wiser to have their car washed by a professional car wash, rather than washing it at home in their own backyard.
The Technical University of Munich has carried out an impartial scientific comparison test in association with Mercedes-Benz to establish the exact ranking of hand washing versus machine washing of vehicles relative to damage to paintwork.
To make the test as realistic as possible, typical family sedans were used - with a few hundred miles on the odometer. It was stipulated that each car was to receive the equivalent of one year's wash stress (about 25 washes) - some cars by hand washing methods, others by automatic carwashing equipment.
To make the test as realistic as possible, and to give both the hand washers and the automatic carwashing equipment something to get clean, five test vehicles were thoroughly coated with a mixture of street dirt, under-fender dirt accumulations, oily water, and thawing-salt residue. This test mixture, inspected under a microscope, contained grit particles measuring between 0.5mm and 1.0mm which are enough to damage the toughest paintwork if not carefully removed.
The Hand Wash
Without having been told the why's or the wherefore's, four men were given the chore of washing four of the test cars by hand. Each person was to do as thorough a job as possible. Since there were four people involved, and since each person used their favorite "tools", together they presented a cross-section of various hand washing techniques commonly used by average car owners.
So the marathon carwash began. The four men showed up in four different sections of town enthusiastically sponging and lathering their test cars as if they were their very own. Bystanders could see one man hard at work in a do-it-yourself self-service type of car wash with high-pressure water facilities; another was busy at home with the garden hose and a water spray-brush. One man scrubbed away utilizing a bucket, a sponge, and a garden hose. One, to the horror of the environmentalists, and in defiance of local regulations, washed his test car at a lakeside.
The Automatic Wash
As the alternative to the perspiring hand washers, automatic carwashing equipment was used to wash the fifth test car. To keep the test above board, the test vehicle arrived unannounced during the hours when the car wash was open for business. The car was washed along with other cars.
The Examination
To measure the extent of paintwork damage, microscopes were available. However, pure reflecting microscopy, as well as electron microscopy results merely in a visual picture of scratches. A comparable measure of true depth cannot thus be achieved. Consequently, a method of analysis was used which could determine the exact depth of the scratches and grooves, namely, the interference-microscopic analysis method.
This method allows the glossy surface, with all of its irregularities to appear like a relief map. An interference band is created and corresponds to the contours. Band distances are 0.27 of one thousandth of a millimeter, thereby allowing even the tiniest grooves and scratches on the gloss to be accurately measured and compared.
The Result
The comparison tests produced results of which every car owner should be aware. Automatic car washing and hand washing have completely different effects on automobile paint.
How does the paintwork of a car appear after 25 washes - equivalent of a year's worth of washing?
The results are depressing, at least to the car owner who, up to now, has firmly believed in hand washing. The deepest scratches after hand washing had a depth of more than one-tenth of the paint surface. Under the microscope, the paintwork looked like a cratered landscape. The paintwork was deeply scored and scratched - the result of dirt and trapped sand particles.
In hand washing, invariably too little water is used. Even with a garden hose and a sponge technique, small sand particles lodge themselves firmly in the fine pores of the sponge or wash mitt and cannot be removed even by good rinsing. Such particles work on the paint surface like sanding discs. Furthermore, the hand washings produced a tangle of uneven scratches in the paint surface.
By comparison, the surfaces of the test vehicle washed with automatic carwashing equipment appeared different. Compared with the hand washed surfaces, it was remarkably smooth, with many very fine markings virtually parallel and uniform - less than .0003mm - the result of evenly moving and rotating cloth pads and curtains. The machine-washed surfaces were in very good condition after 25 washes.
Wash a car by hand or by machine, in either case, it looks immaculate right after the wash. The sophisticated test described suggests that looks are deceiving: The paintwork on a car washed by automatic carwashing equipment is in much better condition than one washed by hand - even though the car owner lavishes tender, loving care on their vehicle.
Eventually, either by force of habit or because the car finish looks dull, the weekend hand washer resorts to the lengthy and back-breaking chore of applying abrasive rubbing compound or similar pastes and liquids to their vehicle. This process indeed restores the luster to the finish. Such "pampered" cars naturally appear to have just rolled out of the showroom. The proud motorist forgets the long hours with the rubbing compound, and is probably unaware that the reason for all that work (to get the scratches out) was their energetic hand washing procedure on previous weekends.
On the other hand, the motorist who uses the services of a professional car wash with their automatic carwashing equipment subjects the paintwork of their vehicle to the thorough, but gentle action of cloth pads and curtains which treat their paint job with tender, loving care. Knowing that the car finish has to have some protection against the ravages of the chemicals in the air and to also provide a barrier of protection against bird droppings and other contaminants, this car owner will periodically apply a coat of wax to their vehicle. At that moment, their car looks as if it had just rolled out of the showroom.
In comparison, although both cars after washing and other treatment will look pretty much the same, a car is actually treated better (especially concerning the paint finish) by machine washing at a professional car wash and the application of wax than a car washed by hand (with the resulting need for the application of rubbing compounds, etc.). However, in the process, the car owner who utilized the services of a professional car wash has saved a great deal of time, labor, and effort.
This article was posted a few years ago, I tried to find the original article but they wanted something like $40-50 so I stopped my research
Is it me, or did the whole point of this article seem to be "Our automated car wash mars less than improperly hand washing your car"? :rolleyes:
Yeah, you know they washed it in as non-autopian of a manner as possible. Dirty brushes, nylon bristles, cheap soap, etc. I'd like to see their test results up against Accumulator's wash method :). I can tell you firsthand, that using 2 buckets, 2 good sheepskin mitts and NXT soap is way easier on the paint than anything else short of a foamgun.
Well I think we ought to do our own "scientific testing" to set the record straight.
Of course the average joe blow is going to mar thier car washing it as they have not been "schooled".
When someone asks me how I wash my car, they get tired just hearing me explain it then say "forget it I'll take it to the car wash".
The whole purpose of that test was so self-serving they ought to be shot for trying it.
So all those pre-Autopian years when I was taking my '99 Ford Exploder throught the Swirl-O-Matic I was actually helping my paint. Ain't I something!
LOL- just kidding
Gary
I have no doubt that if you are the very first car to go through the most perfectly designed automated car wash, using brand spanking new material without a spec of dirt on it, you will do less damage than my neighbor who takes a bucket of soapy water, dips a towel in it, and runs said towel over the surface of their car without hosing off the heavy stuff first.
OK, take a breath....that was a dang long sentance!!!
Conclusive proof? :rolleyes:
I like how they don't mention the type of automatic car wash it was, brushless or just high pressure water. I guarantee the hand washers are using dawn and cheap used sponges or mits. I know some people don't know how to wash there car. I spend an hour after details teaching them how to properly wash there car. I just think it's kind of unfair to state what type of automatic wash and what products the hand washers are using.
scottabir said:
... four men were given the chore of washing four of the test cars by hand.
This is stupid. All they're trying to do is make hand washing sound like it's so bad and so much work. Somebody from the car wash industry was obviously involved in the "study".
Touchless washes use strong detergents, so they tend to strip wax, and on a particularly dirty car, they'll fail to truly get it clean. They work in a pinch (I.E. middle of winter), but don't expect miracles. I do use them occasionally to get off the layer of crud before I qd or QEW in foul weather/far away from home, but not as a primary wash.
Accumulatorette uses a touchless in Memphis when she's visiting her family. Her A8 usually has a recent coat of wax on it, but the touchless she uses has never stripped the LSP or otherwise caused trouble. It has a touchless blower to dry, and must use some decently treated water as the car never has any waterspots on it. But *that* touchless might be better than the norm.
IMO if you hand-dry after using a touchless you're gonna mar it; no way the touchless is gonna get *all* the dirt off and when you dry you'll grind it into the paint.
It seems that most of the responses to this article are negative. I think that I agree with the negative sentiment aimed at the "take away" that the authors/sponsors of the article want readers to have: "Hand washes bad... Automatic car washes good."
However, as others have noted, they compare the results of what I think all of us would agree to be bad hand washing to automatic car washes. My initial guess would have been that this would be a toss-up. Indeed, I would guess that the automatic car wash that they used was actually a better-than-average one in terms of leaving the paint/finish in poor condition.
My point is, I don't find it at all controversial or surprising that bad hand washing is bad for a car's finish. I'm not hostile to the conclusion that an automatic car wash might be better than a bad hand wash. This is the only real conclusion that can be drawn from this article.
I think most here view this article negatively because it doesn't present the reader with (what autopians believe/know to be superior) the third option: a good/proper/careful hand wash. The "research" done in this article would be similar to an article that asserted that drinking beer is better than drinking caffinated soda to stave off dehydration, sponsored, of course by the beer industry. The study's conclusion shouldn't be challenged if all they compared was beer and soda. What should be criticized is that they didn't test H2O in the research.
Believe me, I know my father-in-law can do more damage hand-washing than a drive-thru wash. All I have to do is watch him once do his car: fill bucket with soapy water, dip dirty old sponge in dish-detergent soapy water, wash sides of car, was hood of car, wash wheels of car, wash top and sides of car again (since they are drying out by now), dip sponge in bucket (for only the second time) and wash whole car again (this time going counter-clockwise in circular motions to miss any dirt left from going clockwise on prior passes), rinse (for the first time), pull out dirty towel (that was not washed after the prior use), dry the entire car using the "two-pass opposing circular motion" that he has perfected, ring out sponge and towel so that they are ready for the next hand wash. This whole process takes all of 10 minutes in the middle of a sunny day. Then he looks at me and says, "pull yours up and we'll get it cleaned up real quick." "Thanks, but I'll wash it when I get home."
I just vomited after reading this description.
...and laughed out loud.
:bawling: :spit: :sign
