Accumulator
Well-known member
This topic comes up from time to time and I *usually* tell people not to worry about it. But OTOH I leave marring in my "keepers" because I'd usually rather have imperfect looks than risk a repaint.
Having recently purchased an ETG (which I haven't used yet) and having a *really* pitted/etched/scratched car to do when if finish the M3 (which I'm just rotarying to *death* in an effort to fix scratches), I've been pondering the "taking off too much clear" issue. If I kill the M3 I'll get over it as I'll either sell it anyhow (likely) or get it repainted if I keep it (less likely). But I sure don't want to over-correct anything I'm keeping, so a few thoughts follow and I'd appreciate any comments:
I ran across a thread where RAG did some ETG testing with various combos. He found that to completely remove 2K sanding scratches he had to do two passes with rotary/black Edge wool/HTEC-OPmix. Tested independently of the 2K sanding, said combo removed ~7 microns of clear with *one* pass. (each "pass" was about four strokes back/forth, enough to properly work the product.) That means he removed ~14 microns of clear to remove those sanding scratches.
14 microns = ~.34 mil which is right around ~1/3 mil that's recommended as the max clear you can remove before you precipitate clearcoat failure. Some people think you can take off up to 1/2 mil, but even then that's over the entire life of the paintjob. And all this is leaving out the clear removed prior to the correction by the wetsanding and any subsequent final polishing with milder combos.
So how to do serious correction (uh-oh...like what I'm doing on the M3 :nervous: ) without long-term consequences?
