Accumulator
Well-known member
An another thread, an Autopian posted:
I didn't want to thread-jack with the following $0.02, hence this thread.
It's not like there's no middle ground between doing a flawless 2/3-step correction via rotary and spending forever with a less aggressive tool
And speaking of middle ground, IMO/IME the learning curve for the rotary is three-staged, with the middle one nice and steep; it's the two stages on either side of that that take time/experience:
1) Doing *very* aggressive correction with only a few passes (i.e., with aggressive pad/product/speed combos) is something that could require experience to do safely
3) Doing final finishing on all paints, with zero holograms, is also something that probably won't happen the first few (or first hundred) times
-BUT- The good news is...
2) Doing fairly serious correction in a fraction of the time that a PC/etc. would take isn't very tough. With some study, common sense, and the right mental approach you can get a *LOT* out of a rotary without being a true rotary-Meister (voice of experience here
You might still have to finish out with the PC/etc. but the hard, time consuming work will be completed in a fraction of the time. The big worries- burning paint/etc. just don't happen unless you get careless, it's as much a matter of knowledge-base and mindset as anything else.
I am simply put off by the learning curve for the rotary..
