Having used three of these products with pretty good results, I was curious about a few things.
First let me say that for me, DP 4in1 and ONR seemed to be about the same. I'm not sure that if I didn't know which I had put in the bucket which one I was using. Both seemed just a little smoother/slicker to use for the wash than QEW.
Since the ONR seems to get all the press, why is that?
1. Is it because some of the big name detailers on the forums use it and talk about it more?
Anthony Orosco and Scottwax are two names that come to mind as testers and big promoters of the product.
2. Is it because it is available from more vendors?
3. The price per gallon is about the same and although ONR says you can use 1 oz. per 2 gallons and 4 in 1 recommends 1 oz. per gallon, it seems that almost all the ONR users are mixing the ONR at 1 oz. per gallon as well. On the recommendation of an ONR user, I did. That makes the cost pretty much a non-factor.
4. Is it because the ONR seemed to get a lot more hype when it was released.
5. Is it really a better product?
6. If it is, in what way?
FWIW, I have only used both products as a rinseless wash and have no idea how they compare as a QD or a car shampoo additive.
