That is correct but a few days ago when I did that I got a response 4 times but still could not access the site.For anyone who is having trouble accessing the site the next time. Do the following: at a DOS prompt type in the following:
ping www.detailcity.org, the address should resolve to this IP address 216.246.2.2 if it doesn't this is what causing your problem accessing the site. Your ISP is hitting a DNS server that still has the old IP address. Usually when you move a web site to a different location, it takes 24 to 72 hours to replicate the new IP address to all of the DNS servers located in the world.
DNS servers are used to resolve human friendly names to an address that the computers under.
Ask you shall receive.The woman working for Troy is most likely a web programmer, not a network engineer. You mentioned that when you was experiencing the problem accessing the site, you pinged and got the correct IP address? If so, that means that the DNS server you are hitting are resolving the name to the address correctly. Could be that the gateway server at the hosting company isn't translating the requests correctly to map you to the forum. What kind of error page or errors do you receive when you cannot access the site? If you could screen capture the error page and PM me, maybe I can help.
I must be doing something wrong it is telling me Host not found check and see if name is correct.The 216.24.138.135 is a different hosting company. Sounds like the DNS server you are hitting, hasn't been updated. Type in ipconfig /all and see what your primary and secondary DNS servers are.
