Bunky
Detailing Gnosis
On Autopia, this was added the UDM thread without much fan fare. It appears that they are going to relabel the PC (essentially what Meg's did with the G100) rather than release a new model.
I have a UDM and waiting for it to die since many have failed at least once. They have extended the warranty but we shall see if they repair future ones or send this as a replacement. If mine goes, I may just get something better like the Flex although I know nothing about it. Meg's G110 would be like the UDM but maybe more reliable although they seemed to have the same problems in the first lot. I will not be upset if it fails except it will likely do it when I am in the middle of something.
The UDM by Porter Cable has the same motor as the 7424 and the same power.
The Ultimate Detailing Machine by Porter Cable comes complete with a 1-Year Replacement Warranty. The best in the industry!
*The basic Ultimate Detailing Machine by Porter Cable system is complete with:*
* Ultimate Detailing Machine by Porter Cable Dual-Action Polisher
* DAS FlexPlate 5" Velcro Backing Plate
* 6" Foam Polishing Pad
* Wrench
*Polisher Feature Specification *
* Power 120 VAC, 50-60 HZ/120 VDC
* Motor 110 volt, 3.7 amp
* No Load Speed Electronic variable speed 2,500-6,000 rpm
* Spindle Thread Accepts 5/16 - 24
* Weight 5 1/4 LBS
* Backing Plate 4.75" diameter, flexible, with hook & loop (Velcro) backing
* Wrench
* Weight 5 1/4 LBS
