Street Dreams
...And how we fixed them through practice and experience
Its almost 1am here in the dirty jersey, after working on an impossible Subaru clear coat respray nightmare, I began thinking of some of the silly mistakes I made when I first started detailing. Im not sure why this came up but I thought it may make a good thread, that or I may be sleep depravedSleep
We should all post some info on what we did wrong and how we fixed those problems and make this an ongoing thread.
Some issues I had when I first started detailing
1) UNDERESTIMATING the importance of a super throrough wash process! Getting every area of the paint perfectly clean is so important, not to mention the trim, grills and glass etc. Its so much more difficult to clean dirty areas like rocker panels, underside of side skrits etc AFTER you dried the car. Without the suds and lubricity of a shampoo you will just end up marring the finish. Take the extra time and do it right.
2) Not polishing to the edge for fear of burning an edge. I used to polish a hood for example and end up leaving about 1/2 inch of the edge only 50% corrected or so. I wouldnt do full passes near the edge and I would tend to reduce pressure when coming to an edge for fear of burning. Then when I checked my work in the sun I would have to go back and re-do those areas. You need to take caution when coming to an edge but you cannot skimp on correction, make more passes at slower speed if you have concerns.
3) Forgetting to tape mesh grills and hood vents when polishing. Good luck getting dried polish out of those areas. I now dont take any chances, if it can cause trouble with polishin dust or splatter... just tape it!
4) Dress your tires before sealing the wheels. I used to seal the wheels and end up getting tire dressing around the lip.
4a) Also try not to spray your tire dressing onto the tire, instead spray it onto your applicatior of choice and massage it in. This will save product and provide a neat application without mess.
5) Do NOT wipedown a car with the engine running or with an engine that is not fully cooled down. If you need to do your final wipedown with anything but DI water (QD, spray seal etc.) make sure the hood is cool or you may have streaking issues.
6) Play with your lighting! Angle your halogens high and low, walk back and forth with your handheld light to check for holograms and turn off your garage lighting to get a really clear look at the finish under your halogens or LED. A finish make look perfect with lights looking at it dead on but from a side angle things may be different.
Thats all I can think of for now, feel free to add tips along the way.
