imported_Grouse
First the trailer, 6-8 weeks on delivery of the trailer. I will then send it in to get it wrapped. I am stoked at my future prospects.
Second is the generator and the air compressor.
Third is the New HWE, Pressure washer, Water Reclaimation system.
Your order summary:
Item #: 165967
Description: NorthStar Generator � 18 HP, 10,000 Watt, Gasoline
Item #: 1592027
Description: FREE SHIPPING � Ingersoll Rand Electric Stationary Air Compressor � 3 HP, 10.3 CFM @ 135 PSI, 230 Volt, Model# SS3L3
Item #: 15920083
Description: FREE SHIPPING � Ingersoll Rand Air Compressor Start Up Kit � Model# 97338099
Item #: 159355
Description: Northern Industrial Tools Tire Inflator Gauge, Chuck, and Hose � 1/4in. Inlet, 120 PSI
Item #: 159185
Description: Northern Industrial Tools Air Hose Reel With Hose � 3/8in. x 50ft. Hose, Max. 250 PSI
Item #: 155232
Description: Northern Industrial Tools Air Couplers Set � 10 Plug, 3/8in. Dia, Female
Item #: 155231
Description: Northern Industrial Tools Air Couplers Set � 10 Plug, 3/8in. Dia, Male
Item #: 1586652
Description: Northern Industrial Tools Air Hose � 3/8in. x 50ft, Red, Rubber
Pressure Washer #SCG 4-2400:
3.5 gpm to 2400 PSI, skid mounted, B&S Intek Pro OHV 6.5 hp engine with low oil shut down, oil filter, super quiet muffler and throttle control.
High Pressure Hose Reel
Hey, time is money! Setting up and tearing down jobs without a reel wastes precious time. These quality hose reels carry up to 200 feet of hose, come with connecting hoses and mounting hardware and will get you on the job faster than ever. Rated to 3500 PSI.
Upholstery tool pressure control
The pressure-control adapter connects easily to the pump system and enables any pressure washer to run a variety of profit generating cleaning tools. Preset to 125 PSI up to 500 PSI.
Carpet \ Upholstery tool
Add a 500 PSI rated, stainless steel upholstery tool with 12ft. leader hose and 250° valve for quick, efficient cleaning of auto, home or commercial upholstery jobs.
Hi-Pressure Heater System 120 v AC
Our heaters do an exceptional job on upholstery, carpets, rugs and quick cleaning of the dirtiest engines. The high pressure systems take water to 200°F with pressure up to 500 PSI.
Optional: Hi pressure heater up to 1000 PSI
Model Sirocco PEV2 PRO Vac/Reclaim System
Vacuum Motor
Dual 3-Stage
Recovery Tank
30 gallon
Tank Finish
powdercoat
Lift
170"
CFM
200
AMPS
27
Plug Type
GFI, 3-prong
Auto Pump Out
optional
Hose
25' ft
Shipping Weight
135 lbs.
VacuBermâ„¢
Complying with strict wash water control laws is cheaper than you think! Simply place in gutter ahead of sewer drain, or use anywhere to capture wash water. Vacuum the wash water into holding tank, oil/water separator systems or septic sewer. It's made with abrasion resistant plastic. It's also abuseable, easy to clean and water proof!
Water tank 150gallon
Carrying your own water supply allows you to work anywhere, anytime. We recommend a 65 gallon, rectangular Poly tank: 32" x 20 1/2" x 23 3/4"Or choose from a variety of durable Poly water tanks that will fit in your truck bed or trailer.
Tank Mounting hardware, straps, connect hose, fittings and "earthquake brackets"
High pressure hose
For greater coverage and convenience without moving your machine, add some hose. We recommend 50 ft. of 3/8", 3000 PSI steel braid rubber hose (not plastic!) with QC’s
Optional: Blue non-marking hose R1 or R2
