imported_Dave KG
Okay, performed a test recently on a scrap panel to test the ability of a variety of products to remove swilrs by hand for those who dont have access to a machine polisher.
Each product was tested on a small area of a red metallic bonnet, pre-washed with some steelwool. This left light swilrs and deep swirls too, to test the products and techniques to the limits. Each product was allowed five hits (this is why my arm is so sore!! :lol: ) to work on the paint, and was worked until the product was ready to remove each time, detailed description of each process with each product.... All products applied using a Meguiars Foam Applicator (clean one for each product) and removed with Megs Ultimate Wipes.
So, down to business:
Meguiars #9 Swirl Remover 2
First up was Meguiars #9, a filler heavy product which also contains light abbrassives. Sutiable for application by hand or machine, of course it was applied by hand here.
Before:
This product was applied first of all in circular motions with firm pressure, then in horizontal and verical lines, and then back to circular motions... Took about three to four minutes per hit to work the product well. The residue then buffed off very easily...
Results after three hits:
Results after five hits:
In summary, this was an easy product to use and did a very good job of dealing with the light swilrs (all taken out), and an admirable job of the heavier scratches, around 60% removed. Impressive by hand... Also left a very nice wet and glossy finish, so for working by hand this is an excellent product for swirl removal. A good start to the test! :thumb:
Meguiars ScratchX
An OTC product that is designed to deal with swirl marks by hand, and a product that is often recommended if working by hand. Light abbrassive product.
Before:
This product was applied first in circular motions then in straight lines with firm pressure. It dried more quickly than #9, and went quite tacky but was still very easy to remove.
This was another good performing product from Meguiars, that did a very good job of dealing with the swilrs by hand, only the deeper scratches remaining... an impressive result for working by hand.
Before:
Meguiars ScratchX
Before:
