Test Spot
joe18741
Is alcohol & Water A Good Choice To Strip Polish & Waxes From Test Area
Thanks This My First Post hope I did it right
JOE. R
It will clean it up some what for you but there is always alot of product left behind so go with a clay bar to ensure you get the most off before any work to be done. If not try CarPro Paint Decontamination Kit which IMO works great!
What type of "test" are you proposing? If you are testing machine compounds/polishes/pads to see which will give the best results there is no need for an alcohol water wipe down at that point. Clean & clayed, yes. The wipe down would come after completion to confirm nothing is "hiding" under the residue from polishing.
Thanks for input
Is it necessary to clay a car before you are going
To compound it or is it overkill
Thanks again
