Taking out swirls by hand?
98stang04
Is there anything that I can use by hand (no pc) that will take out swirls, and that can be used under VM and CMW?
-Thanks
-Thanks
It depends on the severtiy of the swirls and your willingness to get sore arms:D , but you want to find a polish that breaks down quickly, e.g. #80 or MPPC.
You can top VM with CMW after prepping with just about ever polish on the market:up
Well the swirls arn't severe, but they are noticable. I don't care too much about removable of the prduct, as long as it will come off, lol.
I would use Sonus SFX-2 then follow with #3. I've tried it to just try it and it worked, because people always ask me "what polish works the best to get out swirls by hand". Use a foam applicator. It sucks because you have to work a 2x2 area till dry. Worth it though. Then go to #3 for finish. It will gleeeem like new and then go to AIO then SG to help prevent swirls. Then learn how to wash your car better.
I find most swirls you can remove by using just klasse AIO by hand.... unless they are really deep.
Megs ScratchX. Since the swirls weren't that severe as you said, you don't need to work it out that much to the extent causing sore arms.
On my red Mustang I hadn't washed it since about 3 years ago, because I was not old enough to drive, and my parents washed it, and didn't really give a crap about it. And my black Mustang it had swirls from the dealer, and I have not put any swirls on it, but the swirls are very minor.
I'll try the Meguire's ScratchX first, and see how that does, then I may order some SSR1 of SSR2 because i've heard good things.
