imported_Indy YZF
My question is about what autopians refer to as Swirl Marks. I have a White '99 M3 which gets about 15K miles a year, but is parked in a garage both at work and at home. I dont think I have one single Swirl Mark. What I Do tend to get from time to time is some micro scratching in the clear coat...These are the kinds of scratches you cannot see in any sun light, but which appear under the lights of a garage at certain angles.
For these types of micro scratching, would products like 3M SMR be good to use? Or are the SMRs literally for the Swirl Marks I dont seem to get. And if so, would I be better off with a glaze? My problem is that Ive done a fair amount of rotary polishing to remove the scratching from time to time...I ve also had excellent results using a product I never read about here: 3M Moderate Strength Cleaner Wax...I like it because its effective at these kinds of scratching by hand with a fair amount of pressure, and, it doesnt force me to wax right after...And its good for targeting asst scratches here and there...I just use a rubber sanding block with a terry cloth, and apply it with pressure back and forth...Many scratches are well removed this way. But because Ive also used the rotary some on the hood, Im cautious of removing any more paint than I have to, hence my thought of the IHG, followed by my wax of choice.
For wider use than the targeted use my agressive stuff gets (Meguiars #2, PI fine cut rubbing compound, FI, etc) , Im tempted by the 3M SMR, if its as effective on my type of micro scratching here and there, rather than all over...Or, maybe I just go about teh asst scratching where it occurs, and follow up with IHG, and then the WAx?
