So I order up some KYB AGX shocks & struts, Eibach Pro-Kit Springs, and some urethane bushings for the front sway bar and rack and pinion (offset since the car will be lowered).
Allright so I go in to get started on my car.
1. Rear end goes smoothly, had to unbult UCA to get the springs in, but no biggie.
2. Front end is a different story. We get the wheels off, and they feel funny, bad news, tie-rod ends are bad. Answer: New Rack and Pinion.
3. So we are looking down at the headers, engine mounts look bad. Answer: New engine mounts
4. Checking out the calipers, BOTH pads are cracked. Answer: Full front-end brake job
5. Other various things, new ball joints.
On the up side, do to the engine mounts, the k-member had to come off. That made quick work of removing the exhaust, which gave me more time to run all of my parts through the 200 degree water vat.
Tommorow I am supposed to get the engine mounts in from O'Reillys, luckily they had the GT R&P in (good tight ratio). I am also going to go off and degrease and dust black the K-member to make it look good. Oh and I get to use convertible engine mounts, so the engine is going to get lowered just around 3/8 - 1/2 of an inch, which I am looking forward to.
Life is good
Life is good
