Street Dreams
Ferrari 599 GTO in need of extensive paint correction. No need to post any technical information about this car, its a GTO, and yes its wonderful.
Most of the usual Ferrari refinishing problems:
-Sanding scratches
-Rids
-Rotary Holograms
-Heavy Swirling
... and overspray, lots of overspray!
Very pretty...
Very swirly...
Wheels soaked with Brake Buster, very mild wheel cleaner with no iron removing properties. My choice for cars with carbon ceramic brakes. Tires and wheel wells scrubbed clean. Stiff bristle brush is ideal for removing most of the old tire dressing.
Started with a prep wash, rinsed down and foamed followed by a 2 bucket wash using a mixture of citrus soap and some Lusso auto bathe. The finish was then clayed to remove some of the overspray...
After claying the car was nearly stripped of all old protection, 2 IPA wipedowns ensured a 100% clean finish ready for paint correction.
Here is the prepped finish out in sunlight, some heavy overspray on the passenger side
Back inside I measured the paint with a paint thickness gauge. Very healthy readings always good to see before beginning a lengthy paint correction.
Mesh grilles/vents taped off. Getting polish splatter or dust in there will take forever to get out!
Better idea of what the overspray on the passenger door looked like, clear line shows wherever the car had tape on it from delivery
Some closeups of the finish under LED light (640lumens worth)
I started with the worst area first, started with foam and upgraded to a 3" wool pad on the rotary to cut out the heavy defects followed by foam compounding and then foam finishing using both Meguiars and Menzerna
Before...
After... its that simple!
Okay well not really, rear plate area under the LED, much smaller defects show up...
After compounding and polishing
-Sanding scratches
-Rids
-Rotary Holograms
-Heavy Swirling
Very pretty...
Very swirly...
Before...
