imported_RedlineIRL
I have been noticing that on my car that the hood still looks kind of dirty on it when looks at it in the sunlight in the right angles and up close. With the way my car is parked the sun shines down from the backside of the car, and me looking head on at it. Being GM bright red, it shows any kind of imperfection. It has a looks almost as if water was lightly misted on it and drived.
I know nothing has been sprayed on it, and it has not been expoosed to sprinklers, so that is not a possibility. I can run my finger across and can't feel like there is anything on the suface. I just machine polished it with my PC 7424 back around the first of August with Optimum Compound II and Optimum Polish II, after doing this it was absolutely pefrect and looked like a mirror. I then applied 1 layer of BFWD via PC7424, cured for over an 1 hour, and the car was not exposed to any sort of moisture for well over a day. It doesn't go any more than 2 to 3 week max in between washings, so it's not like I let stuff accumulate on it big time.
Unfortanetly my car sits outside for now (currently looking for a place with a garage), so on more humid evenings it does get dew on it. It usually not heavy at all on the hood, not to the point that it beads and rolls off. I leave earlier in the morning, so it doesn't sit in full sun to dry on it.
Does this sound like dew moisute could be doing this? Even though the BFWD is not as hydrophoc as it once was and the beading is larger after 3 months, should this have at least provided some sort of barrier? The BFWD does still bead, and the water does roll off without puddling. Is BFWD not really suited for this type of exposure, or is it more intended for weekend vehicles? I hate to have to machine polish again after 3 months, until I can get it garaged, especially after using Optimuum Compoound II. I don't want to end up burning through the finnish from polishing.
Besides the coattings like Opticoat and Cquartz, what kind of LSP can I use that can provide the most maximum protection on the hood against mositure and any kind of head that may be generate on the hood from the engine? I have some DG 105 and FK1000P, should those be a better solution than BFWD at providing thoe most maximum protection?
