imported_Homer
Some shops like to steam clean engines before working on them. I guess to get rid of any crud. Ours is always clean, but they still want to clean. I think steam cleaning may be harmfull to some engine parts.
I would encourage detailers to cover first certain components before engine cleaning. I you use a steamer that allows me to control the PSI. I only use distilled water in my machine. My steamer came with a ton of different adapters which allows me to work around tight areas. It also has a long wand for longer reach. I use an safe engine degreaser on what I want cleaned. I can always control just about any area. I also have other tools in a smaller version of a pressure washer that works with my air compressor if I need more psi. Make sure to have an air compressor to blow out any sitting water. Pay close attention to all the electrical connectors. You want to make sure there dry. I don't personally like using pressure washers on engines while the car is in my care at my customers house. Now days a good puddle of water from underneath the engine bay can cause a short or a sensor,or a check engine light. Now in the other hand if the car your working with is at the mechanics and the engine is being work on or the engine is out perhaps working a plan together with the mechanic would be the safest. I do that when the opportunity is there. Some times if I'm working on a certain type of car I call the mechanic I know. I ask him for feed back on the type of engine that I'm going to work with. Send your mechanic a large Pizza once in a while. He will start to like you more and be more helpful in the future or perhaps get you out of a jam if something went wrong with the engine you were detailing. May the steam be with you!
Great answers, Eddie EXCELLENT sugestion on the mechanic and the pizza offering. A little "pizza" goes a long ways to building that relationship.
Yup, I'd much rather send Pizza to the dealer than a flooded out car $$.![]()
Engine Compartment High Pressure Steam Cleaning / Power Washing:
Most engines are rarely so encrusted with automotive residues and dirt that normal, low-pressure degreasing methods fail to provide proper, efficient cleaning. High-pressure engine water / steam cleaning are unnecessary and should be restricted to extreme cleaning jobs, such as commercial trucks, off-road vehicles, etc.
The engine compartment is designed to resist water ingress, it is not waterproof / watertight. Rain or water splashed up into the engine is at very low pressure, very different from a pressurised hose or steam
High-pressure steam cleaning can force solutions into the engine harness sheath and associated cables, causing unusual problems that would not have occurred otherwise. Once steam is applied to a cold metal surface it condenses and becomes water that may be in a place that it cannot be easily removed from.
An extract from one of a series of in-depth ? detailing articles by TOGWT ?
Wouldnt a steam cleaner and a pressure washer give two different results. Steam may be a high pressure but it's not a direct blast from a hose like a pressure washer. The question was about steam cleaners and it has morphed to pressure washers. Is there a difference that can be clearly determined to each being potentially harmful to the electronic of a motor?
